Rock Crawling Forums
Sometimes there are brakes and other times there are not ?
Reply to thread
Message
<blockquote data-quote="skipnrocks" data-source="post: 712647" data-attributes="member: 3166"><p>Finally figured it out. I pulled off the calliper I suspected had the stuck h block and it was indeed stuck. But with it off I could see a small contact spot between the caliper and the inner c. So I turned the steering full turn and sure enough when turning hard driver the caliper would hit the inner c and it would slide the Piston back in and then there would be no pedal till it compressed back down. Like when doing new pads and getting in. The first time. I took a flap disc and clearances just a little and the problem is gone. Lol what a process.</p></blockquote><p></p>
[QUOTE="skipnrocks, post: 712647, member: 3166"] Finally figured it out. I pulled off the calliper I suspected had the stuck h block and it was indeed stuck. But with it off I could see a small contact spot between the caliper and the inner c. So I turned the steering full turn and sure enough when turning hard driver the caliper would hit the inner c and it would slide the Piston back in and then there would be no pedal till it compressed back down. Like when doing new pads and getting in. The first time. I took a flap disc and clearances just a little and the problem is gone. Lol what a process. [/QUOTE]
Verification
Post reply
I am moving to Tennessee
Latest: hokie_yj
Today at 7:45 AM
Monday at 11:55 AM
