Rock Crawling Forums
Toy 3.4 front crank seal/cover?
Reply to thread
Message
<blockquote data-quote="Rix" data-source="post: 1209852" data-attributes="member: 17306"><p>Yup, the mid coiver overlaps the lower cover.</p><p>if the crank seal isn't leaking (they RARELY ever do, even at 250k plus) leave it alone.</p><p>however... the mid cover aslo covers the water pump.</p><p>Might wanna go ahead and take 20 minutes and pull it all the way down and check it.</p><p>New (toyota) water pumps have a rubber and steel gasket, older and aftermarket (crap) water pumps use a groove and RTV/F.I.P.G., or paper-ish crap gaskets.</p><p></p><p>make sure you crank that pulley down TIGHT.</p><p>Something like 188 ft-lbs or something IIRC.</p><p>the damage to the crank snout is sometimes terminal for the crank.</p><p>Machine shops have to play lazarus and weld and re-grind the snout.</p><p></p><p>the lower cover has a small drain hole, I don't think it'll really make any difference if you fix or replace that cover.</p></blockquote><p></p>
[QUOTE="Rix, post: 1209852, member: 17306"] Yup, the mid coiver overlaps the lower cover. if the crank seal isn't leaking (they RARELY ever do, even at 250k plus) leave it alone. however... the mid cover aslo covers the water pump. Might wanna go ahead and take 20 minutes and pull it all the way down and check it. New (toyota) water pumps have a rubber and steel gasket, older and aftermarket (crap) water pumps use a groove and RTV/F.I.P.G., or paper-ish crap gaskets. make sure you crank that pulley down TIGHT. Something like 188 ft-lbs or something IIRC. the damage to the crank snout is sometimes terminal for the crank. Machine shops have to play lazarus and weld and re-grind the snout. the lower cover has a small drain hole, I don't think it'll really make any difference if you fix or replace that cover. [/QUOTE]
Verification
Post reply
Yesterday at 5:33 PM
C
Latest: chaplinfj60
Yesterday at 9:54 AM
Jimmy Smith Rockbouncer 383 Stroker
Latest: Zjman
Wednesday at 10:15 AM
A
Jeep Wrangler Sahara Wheels
Latest: A.C.
Tuesday at 9:56 AM
B
Latest: Bebop
Monday at 8:52 AM
