liv2mx said:trickflow from summit.no issues at all.they are 100 bucks.filter and pump..done.
TBItoy said:Airtex e8228
patooyee said:I'm pretty sure Trickflow = Airtex.
Airtex e8248 is the same price, size,, shape, and fittings but flows more at the same pressure in case one ever wanted to go to a more powerful motor.
TBItoy said:yep, that's the one I meant to post:
8248 = 70gph 120 psi $136
http://www.summitracing.com/parts/ATX-E8248/
8228 = 38gph 125 psi $106
http://www.summitracing.com/parts/ATX-E8228/
Trick Flow = 43gph 85 psi $115 and it comes with a relay/wiring/fuse looks like the same mounting and plunbing as the Airtex pumps
http://www.summitracing.com/parts/TFS-25004/
Trick flow pump looks like the best value.
That Walbro pump is all metal and looks just like the ones Holley sells in their "kits"
I'd say any of them would work just fine for a 5.3.
Sometimes you can find them even cheaper on Amazon.
patooyee said:e8248 is $90.79 on rockauto.com. Just do a part number search for e8248. Once you sign up for an account they send you regular discount codes via email for another 5% off, whichs brings ti down to $85.25. The 8228 is $76.99 on Rockauto.
I believe most fo the Summit brand pumps are also rebadged Airtex.
TBItoy said:Rock auto is awesome.
I have a an shop account at Napa and get the same pricing as all other Napa auto care shops and a lot of the time Rock Auto is still cheaper :****:
the 5% off usually covers shipping too
85toyo said:A friend recommended a e2000 pump for my lq4. Has anyone else used one?
