paradisepwoffrd
If they are making a bracket for wilwoods, might be feasible to adapt some type of Toyota caliper. IIRC, folks are using the newer Toyota stuff with good success and better braking.
If you keep the rotor diameter close (13+"), the smaller dual piston calipers will likely work fine.
It won't be as good as stock parts, but not as heavy and won't require boosted master. In a lightweight buggy, I'd like to run manual brakes for weight and simplicity.
