14 bolt ff nose bearing
tommy450r
dyersburg tn
I am lucky enough to own one of these rare 14 bolts with the small pinion bearing on the nose. What can I do about getting another bearing?
This axle is going in the front of my bouncer could i machine some of that oiled bronze to the right specs and run that or do I need to locate a bearing?
Part number on old brearing Is bc-57524 brand is Torrington thanks for any help...
hokie_yj
Surgoinsville, TN
Found it. It was on Facebook. Hard Motorsports and Fab.
https://www.facebook.com/permalink.php?story_fbid=1590890454488843&id=1589448991299656
tommy450r
dyersburg tn
Thanks for the link!!! I guess I will go that route but I'm not paying 125 bucks for that little piece lol I will machine my own. What would make that piece so high??
extremetownie
Check with HEMAN FAB "traveler" on here .He has a new super secret bearing replacement that fixes everything. I have ran the factory bearing and it broke right away. I ran the bronze bearing and it worked but had to be replaced often. Now i am running the new bearing from Heman. It has been in for 6 months and is perfect. It is the new greatest 14 bolt bearing ever.
tommy450r
dyersburg tn
I will give him a call tomorrow thanks for the info.
joho75287
Denison, TX
OK, trying to learn here, so be gentle, use lube and go slow....
What causes this issue? Is it pure design or is it related to setup and pinion angle or a combination of all of the above?? I run a 14 bolt, but not in a bouncer, trailer rig/crawler and am trying to figure out if I need to be proactive here...
tallnate
Nashville TN
The cage / frame structure of the bearing can fail and once that happens it doesn't take long for those roller bearings to find a new home in the base of the housing. I've had it happen to me once. Don't know for sure what causes it but I'd assume it has to do with an incorrect preload on the pinion bearing.
extremetownie
It happens because of deflection of the pinion. When you hitting rocks and throwing more hp than it was designed for the pinion will try to move away from the ring gear. That bearing is the weakest link.
tallnate
Nashville TN
Agreed, deflection causes the issue but I think what caused my straddle bearing to fail was an increase in deflection of the pinion due to the fact that my pinion nut came loose which caused me to lose the preload on my pinion bearings. I'd replaced my crush sleeve with a solid spacer about a year before that, and I'd reinstalled the old pinion nut and it just didn't stay locked tight like it was supposed to. Installed a new pinion nut and everything has been good since, straddle bearing included. thumb.gif
Primary
HardlineCrawlers Assistant
Here are some related products that HardlineCrawlers members are talking about. Clicking on a product will take you to HardlineCrawlers’s partner, Primary, where you can find links to HardlineCrawlers discussions about these products.
