2006 LJ RUBICON
vooduchikn
New Member
MILITARY PCS to ITALY - figured I throw her on here before I stick in long term storage because who knows when I will be back stateside..
Street legal and registered/located in La Vista, Nebraska.
$17,500 OBO. No trades please.
2006 LJ Rubicon (Black on Black) 4.0 109,1XX miles located in Omaha, NE.
4.0 inline six
Banks Intake
6 speed (NSG-370)
4: 1 transfer case (NP-241J Rock-Trac)
Front/Rear Factory lockers
Factory AC/Heat
Heated front seats
Soft top/Full doors
Fresh powdercoat on both bumpers, fenders, rock rails, rear armor, tire carrier, Antirock arms, and door handle paddles.
Reliable Daily Driver and Weekend Warrior. Has done some tough trails and is built with quality parts.
Adult Owned: This jeep is not a show rig or a mall crawler. It has been wheeling, camping, overlanding, trail riding, etc and wears some very minor evidence of those trips. It has never been wrecked, flipped, beat to hell, sunk in a mudhole/river, or abused.
Needs absolutely nothing to go wheeling/daily drive today!!
Some wheeling links:
BUILD SHEET:
Suspension:
Savvy/Currie double adjustable short arm (aluminum) with Johnny joints (all ends) and front and rear Currie track bars
Currie 4" dual rate HD springs
Fox 2.0 shocks.
Fox 2.0 steering stabilizer
Currie Anti-Rock (front)
OEM sway-bar with Currie extended links.
Front end.
Rubicon D44 (4.56 Yukons)
RCV axle shafts (Lifetime no BS warranty if you can break them)
RCV axle tube end seals
Currie Correct-Lync steering.
High Angle Driveline 1330 double cardan drive shaft (grease-able)
In the middle:
Undercover Fab Tummy Tuck with LoPro transmission mount and rerouted exhaust.
Relocated transfer case shifter bracket
Front/Rear Air locker pumps relocated to under the hood (drivers side)
Borla exhaust (rerouted for tummy tuck).
Rear End.
Rubicon D44 (4.56 Yukons).
High Angle Driveline 1350 double cardan drive shaft (grease-able
Body armor/Fenders/Bumpers
POISON SPYDER CUSTOMS Built for the Hammers (BFH) front bumper with trail stinger and D-ring tabs
POISON SPYDER CUSTOMS Rock Brawler rear bumper with D-rings and receiver (comes with 3 hitches)
POISON SPYDER CUSTOMS front fenders (5" flare) with aluminum full inner fenders
POISON SPYDER CUSTOMS Rocker Knockers with slider bar
POISON SPYDER CUSTOMS Crusher Corners (5" flare)
POISON SPYDER CUSTOMS factory welded full cage with welded in grab handles (Behind front seat crossbar not installed yet but comes with it.)
(all Poison Spyder components and tire carrier have fresh black satin powdercoat - primer and topcoat)
Kilby Gas Tank Skid
Lights (LED inside and out):
LED Pillar Cube lights (on the SPOD)
12" LED light (winch mount on the SPOD)
LED programmable rock lights (8 total- SPOD) Multicolor/White and very bright
LED Ghost ring headlights (DOT approved)
MAXBILT LED rear tail lights
Other stuff
Tire carrier with fresh stainless hardware (fresh powdercoat)
Warn 9.5 HS with Warn synthetic winch rope/hook
Trail Dash programmer/OBDII tuner.
Bestop full soft top on LJ factory frame – No rips, tears or broken zippers.
Gearshade sun shade under the soft top, extra grommets added in rear.
Rightline window carry bag (fits all zip out windows rolled up in one bag)
5 - 35x12.50X15 Wrangler MTs (Spare is new other 60%) on black aluminum rims.
Full BedTread inserts (front/rear/tailgate) instead of carpet.
Optima red top battery
Full doors with mirrors
Driver/Passenger Mirrors for going doorless (still in the box)
S-POD (6 switch, 3 slots available for expansion)
Aftermarket deck/BluTooth, speakers/center console Sub
High Lift Jack mounted to cage with locking mount.
4 D-Rings (2 rear/2 front)
Recovery strap
Some random spare parts that go with it.
IM here or text: 808-398-0087 (preferred)
