TacomaJD
I LIKE CHEAP STUFF.....
2008 Massey Ferguson 3635
Massey Ferguson DL 250 front loader
78 hp
854 hours
12/12 transmission (4 speed transmission, 3 speed transfer case)
This totals to 12 gears for forward and 12 gears for reverse.
This tractor was my wife's father's. He passed away a couple years ago and we have no need for a tractor of this size. The joystick was broken, so I put a new joystick and new RC cables on it. I also got the seat recovered. It has been used on a chicken farm, so there are signs of use and a little surface rust, but overall it is in good shape with relatively low hours. I've seen 2 others listed online for much more that also had double the hours. I believe this one also has what is called a power reverser. It has the forward/neutral/reverse lever on the steering column and there is a button on the transmission shifter you can push that makes it go into neutral as well.
The bad:
Something is going on with it recognizing that it's in forward or reverse. It has the F-N-R shuttle shift on the steering column and standard 12/12 transmission gears. Transmission light comes on sometimes and it won't go forward or reverse. Cut it off and crank it back up a few times and eventually it will go. Doesn't happen all the time, sometimes it may not do it at all. I moved some brush around on our property with it the other day, then went to move it so I could mow the following weekend, and it wouldn't go without cranking it a few different times. Cranks and runs perfectly, transfer case and transmission gears all shift perfectly. I have no idea what is wrong with it, has to be electrical like a sensor or bad/shorted connection somewhere because when it works, it works flawlessly. If the transmission light is fully on, it won't go. If the transmission light is only flashing or off, it will go just fine. It just started this earlier this summer. We've moved it around to store it several times since her father passed, driving several miles across town and such, and never had a single problem til moving it around recently at our house. It has a shared hydraulic fluid system and it is full, so it's not a low fluid issue. With that said, it is priced accordingly. If it were not for this issue, it'd be an easy $20k+ tractor.
$16,000 obo
Located near Sylvania, AL 35988
Contact Josh at 256-six three eight-5336.
Please text or call.
I stay busy so please leave a voicemail, email, or send text if I am unable to answer and I will return your call asap. Thanks!
78 hp
854 hours
The bad:
$16,000 obo
