2015 xp 1000 4x4 problem
sdbangel
Member
If anyone could help me out it would be appreciated
I have 2015 xp 1000 rzr 4wd works fine in reverse but front
wheels do not pull while locked in 4wd going forward
E.Conkle
knock the roll pin out on driveshaft and pull the shaft off the output of diff. unplug diff and take 4 bolts out of the frame. i am guessing you know how to pull front axles? if not just jack up the front and undo lower ball joint and pull them out, sound like a roll pin problem or armature plate. i would go wicked weasel and 1/8" roll pin. $100 upgrade if you do it yourself. the diff isn't complicated. pm me and i will send you my number to walk you through it
Primary
HardlineCrawlers Assistant
Here are some related products that HardlineCrawlers members are talking about. Clicking on a product will take you to HardlineCrawlers’s partner, Primary, where you can find links to HardlineCrawlers discussions about these products.
