For Sale 2016 WOD Evolution "1985"
CHASMAN9
Hardline OG Administrator
Staff member
Chelsea, Al
2016 WIDE OPEN DESIGN EVOLUTION
“1985”
$56k
(POSSIBLE TRADE FOR RAZOR 1000 PLUS LOTS OF CASH MY WAY)
Chassis-
Evolution with additional rear support bars- powder coated
115” wheelbase
Aftermarket doors/ hood/ shifter tower done by BustedKnuckle off road and painted by Jason Hagler (Advanced Collision)
“One OFF custom dash”
Full panels with roof
Autometer gauges include- FUEL, Voltage, trans temp, water temp, oil pressure, tachometer
NEW- push button green lighted switches (interior LED lighting, rock lights, headlights)
Fox remote reservoir shocks with QA1 springs
Fox bump stops on all 4 corners
Polished aluminum link bars
Dual Wilwood brake cylinders
Brake lights
Kirkey 55 series seats- 18.5” hip width
Covers have been reupholstered with EXTRA padding and with WOD stitching
G-Force 3” belts (5 point) with Camlock release
Grant 11.5” steering wheel with quick release
Jazz aluminum fuel cell
Cooler storage area
Griffin radiator with dual fans (computer controlled)
Fire extinguishers (2)
Optima (red top) with Quick car kill switch/ dash mounted
Raceline 17” beadlock wheels
43” TSL stickies
Engine:
LQ9 6.0 with Texas speed cam (approximately 525hp)
Moroso oil accumulator
Remote mounted coil packs
Aftermarket fuel rails
Aftermarket injectors
Aftermarket polished aluminum intake
Tuned by James Schofield (6/2020)
Transmission:
NEW-PTC th350- reverse manual valve body
Hurst pistol grip Quarter stick shifter with cover
Atlas II 3.8 with advanced adapter knobs
Front axle- 14 bolt with Spider Trax 300 m 40 spline shafts with Superjoints
Solid inner C’s an knuckles
NEW-Solid Drive Flanges
BTF hi steer arms
NEW-PSC double end ram with Heat sink cooler
PSC steering reservoir
3:73’s
Spool
NEW-SOLID diff cover
Automotive grade paint
Rear axle- 14 bolt with Mark Williams Full Floater 40 spline shafts
Spool
All plumbing in AN fittings and braided lines
Warn VR8000# winch (cutdown drum) with interior mounted remote
Aluminum hawse
Located in central Alabama 35043
(205)482-5628 cell or text
Beerj
Sonzabitches!
Amish Country
I noticed the rad hoses in the back are crossed. Is the coolant being fed from the lower connection and running out on the upper?
CHASMAN9
Staff member
Chelsea, Al
The lower right frame hose (coolant runs to and from inside frame rails) is return from motor that drops in the top left inlet, then bottom right radiator outlet goes to left frame inlet back to the motor. The fans are controlled through the ECM to tell them when to come on and never gets over 215. I have relocated the transmission cooler to the rear underneath the cooler rack now and the fan is sensor controlled.
CHASMAN9
Staff member
Chelsea, Al
Bump up. Still open to ideas. No Travis, still not interested in your half f#@%*d chicken.
CHASMAN9
Staff member
Chelsea, Al
Primary
HardlineCrawlers Assistant
Here are some related products that HardlineCrawlers members are talking about. Clicking on a product will take you to HardlineCrawlers’s partner, Primary, where you can find links to HardlineCrawlers discussions about these products.
