This buggy started life as a 76 Jeep Cherokee. There is only only a small piece of frame and the original motor left from the Cherokee. This is a very capable buggy. We run 5 rated trail all day without problem and have enough room for the whole family. It is ready to wheel now needs nothing. I hate to sell,but we are getting ready to build a new house and will not have time to look at it for the next 2 years.
Specs
Drivetrain
AMC 360 on propane. New cam,oil pump and timing cover last summer. Has been converted to a GM one wire HEI . Run good and does not overheat even on 100 degree day. The driver may have a heat stroke with black roof and seats.
400 Turbo trans with shift kit
203/205 doubler 203 is upside down for ground clearance. Wagner Machine shop doubler kit. Triple stick and modified for front digs.
Axles
Front
GM Dana 60 with Detroit locker,35 spline Yukon shaft and drive flanges. Yukon 5:13 gears
Rear
GM HD 70 retubed to be centered and converted to a steering axle. It has Spicer 5:13 gear,welded carrier, Foote USA 35 spline inner axle cut and splined by Branik machine.
Yukon super joints and 35 spine stubs with driveflanges.
Suspension
Front
3 links with coil springs and a panhard bar. Lower links are 2" DOM with trail gear creeper joints. Upper and panhard bar are solid bar with 3/4 Heims. Rancho 9000 shocks
Rear
4 link with Fox 2.0 air shocks and an sway bar. wish bone on top of the axle. Lower links are 2" DOM with trail gear creeper joints. Upper link is square tubing.
Interior
Corbeau Seats with 5 point harness in front with an Explorer back seat that is 32" wide. Have had 2 adults ride in the back for full day of wheeling. You just have to like each other alot.
It has a 12 volt guy switch panel for all the wiring. also includes Stereo and CB
Steering
Front
Full hydro Saginaw pump with a combine orbital valve running a 2.25 PSC single ended steering ram.
Rear
12 volt electric over hydraulic pump controlled with a winch remote running a 2.5 single ended ram. The rear steering Knuckles are turn 180 and high steered. The ram is mount above the rear drive shaft to stay out of harms way.
Tires and wheels
42" Iroks that are about 60% tread on re centered H1 beedlocks with Staz work PVC inserts.
Misc
It has a 9000 lb superwinch with rope and dash mounted controls.
This rigs comes with 4 Propane tanks, grease gun for the superjoints, and Spare 42" tire
This has been a great buggy it is very easy to work on. With the single wire HEI you only need 2 wires to run the hole rig.
Asking $15,000 will consider trades for a side by side, full size pickup,
Located in Springfield,MO
Call or Text Paul 417-755-3540
I can't respond to calls during work. I will respond after 4 P.M.
