Warewolf SD
Reaching out since my buggy don't run and I cant be out playing in it today. Du
I have a 4L60E that has a Transgo stick shift kit and a 46-MOD (vacuum modulated line pressure).
It bypasses all the electronic control and makes it basically a manual valve bodied trans.
My problem is the trans will not shift into third or fourth. Has 1st, 2nd, reverse and park but will not shift into 3rd or fourth. you can move the shifter into position but the trans maintains speed like its in second still. Im hoping for a trans guy or somebody who has had this problem before to guide me in the right direction. So far hours of internet searches and message board scrolling has accomplished very little.
Trans is freshly built to beat on. New torque converter and I have verified line pressure is around 80 at idle and varies with throttle and rpm as it should.
Also engine braking works in 1 and 2.
Please if you have any ideas.
Thanks
Thanks
