5.3l LS Has No Low End Power
Gadametz
Little Rock AR
I have a buggy that I've had a ton of power/ engine issues with. It has a 5.3/ th400/ np205. When crawling it has almost 0 power. It doesnt even have the power to pull the buggy up a hill or turn the tires at low rpm from a stop. If i get a rolling start and hit above 2k rpm's it has plenty of power and will go up anything. The entire fuel system is new except injector and maintains 62psi fuel pressure. Any ideas what is causing this? It has rockwells on 43's. When I say it loses power it literally won't turn them, and the engine wont rev any higher. It'll do a hard hill climb fine
was your th400 from a diesel truck ? and you still have the stock diesel torque converter (which is like a 900rpm stall or something silly low)
if the cam is too "big" (no low end power/too much overlap) and the torque converter is stalling too low, then it will be bogging hard off the line and loading up... but I assume you know that since you're mentioning the stock stall.
but is it stock for a diesel? I think even the stock stall spec for a big block truck was like 1000-1200 rpm?
Believe its an 1800 stall. That's about where it bogs but over that and it has tons of power
Have you checked for codes?
Unplug the MAF then start it and see if it's any better.
Watch your timing with a scan tool. If the timing is retarding while it has no power you need to replace the knock sensors and sensor harness. Water gets inside and destroys them. That was the problem on my 6.0 anyways. Make a silicone bridge to channel water around the new ones.
It hasnt always done this
Ah, well that makes a bit of a difference. The first post read like it was new (or new to you) and had always done it.
I'd look at timing and knock sensors like Sawzall said... the same-ish thing happened to my daily driver (of course it was throwing codes too)
whoever flashed the PCM may have turned off important codes (seen it happen more than once)
What codes should I look for? I'll be back at the shop/ tuner tomorrow
my new build did the same thing this weekend and when we put the scanner on it it showed knock sensor codes, cleared the code and rode the rest of the day without issue. I will be ordering new sensors this afternoon
