krackem
Build-Bend-Weld-Break -Repeat
My truck has started to not charge the battery and volt gauge it stays around 11volts, and will not start a new battery after 3 hours riding . Ive checked fuses(good)alternator (good) but the low volt light in the cluster don't work (checked bulb and also good) but do sent come on with key in on position. Boosting off and at first alternator. Put 14.5 volts out then falls I quit reading at 8 volts, anyone got any ideas on where to start lookin for a problem or what the wire should read on a volt/ohm meter
