Air shocks vs coilovers
Jvfolds
Bootlegger, Utica ky
Utica ky
I'm running coil springs and shocks on my buggy as of now what are pros an cons air shocks vs coilovers any advice would be helpful. My buggy is not a hill killer. I'm running a 1.6 liter geo tracker with 4.24.1 geas in t-case toyota axles 529 gears locked with 42's I typically like technical rock piles and some big obstacles on the trail. Prefer something somewhat simple to setup and not alot of maintenance and tuning. Thanks for any advice.
Jvfolds
Utica ky
Any particular reason. I've never ran either always been coil springs and shocks. But getting tired of replacing springs
mac5005
Rocky Mount, NC
For that rig, i wouldn’t hesitate to do 2.0 air shocks.
I would put the most oil I could get in the shock. (Max oil -10cc) as to not hydro lock it.
Set the n2 pressure k get ride height and roll.
Be prepared to pull them apart and pull some shims off the piston to free up the valving some
It’s amazing what you can get out of a set of air shocks if you aren’t afraid to tune them
P
If its free, its P
Staff member
Your Mom's House
Agree , and sway bar the rig. They arent bad on light rigs and the type of wheeling you described your into sou ds like a good match
Jvfolds
Utica ky
Thanks for all the input much appreciated looks like I'm gonna invest in some air shocks. Definitely not scared of a little work and test and tuning.
TacomaJD
I LIKE CHEAP STUFF.....
Rainsville, AL
2.0's should be plenty for ypur rig, 2.5's may mean less tuning to get them to work "good enough" though. Refer to video below on how capable air shocks can be if set up right. Also, read all you can about how air shocks work. On a super light buggy, I would have them mounted to where when aired up to the ride height that you are looking for, there is only about 4" of shaft showing. No more than 6". That goes for whatever length shocks you end up running. Shaft showing should still be the same.
Edit, forgot to link vid.
https://youtu.be/uqcU3jvcBkg
skipnrocks
Billings Montana
Just out of curiosity if I can see the debait between coilovers and airs and if your leaning airs why not ORI? much easier to tune without the unloading or need for bumps. I have them on a 2k rig and they were just as easy to tune as with my 3500lb rig and my 4800lb rig.
I haverun all three and love my oris hands down.
TacomaJD
Rainsville, AL
Re: Re: Air shocks vs coilovers
Cost, I'd imagine.
POR
You don't need bumps with any of the shocks. To say ori's are easier to tune is a false statement. Aren't ori's on a 10 month back order right now anyway?
dwa2469
22RTE Buggy,LC Axles,39 reds
Tullahoma, TN
I have them and if you are crawling they are great and easy to tune. As far as back order, I think you are correct.
poolman
HC Supporter
I have a set of 18" I'm considering selling.
TBItoy
Dodson Branch, TN
Cons:
They cost more than what you got now
Pros:
They are small and easy to package on a vehicle
They'll hold your rig up
why are you having to replace springs? stretching them and they're breaking?
what springs are you running? short stiff ones?
POR
Can you explain how they're easier to tune? Everyone i know that are running ori's like them, but they also like air shocks and coilovers as well.
I'd still run a sway bar with ori's.
Primary
HardlineCrawlers Assistant
Here are some related products that HardlineCrawlers members are talking about. Clicking on a product will take you to HardlineCrawlers’s partner, Primary, where you can find links to HardlineCrawlers discussions about these products.
