AngryFab Toyota Buggy
smbroady82
Huntsville, AL
Angry Fab Toyota Buggy
$22k obo with all spares
$20k buggy only
$19k buggy only
Huntsville, AL
(256) 658-712two
No trades on this one folks. Thanks
Basic rundown:
22r on propane
5 speed
Dual cases w/ 4.7 rear
Toyota axles f/r 4.10s
Weighs 3018lbs
Front has 30 spline chromos , 6 shooters , ARP studs , drive flanges , TG ram , trunnion eliminators
5-6 rides on new housing , truss done by Mo.
Rear stock IFS shafts
Disc Brakes all 4 corners
Corbeau seats (BAJA SS (wides I think))
50 cal padded 2" harnesses
Rear mounted aluminum radiator (I added a fill point at the t-stat so it's super easy to purge air)
Stays nice and cool now
Autometer gauges
Wilwood pedals / resis
Led cubes
Rock lights
4 linked f/r (7/8" joints) (steel links)
Push button start
Newer 11.5" suede Longacre steering wheel w/ disconnect.
Aluminum Raceline Beadlocks (one has steel ring.. why you ask? ... no clue ‍♂)
Smittybuilt winch w/ synthetic rope.
Comes with 3 aluminum tanks.
Chassis was powdered about a dozen rides ago. (2 stage) by the Hollingsworths in KY.
Newer build, maybe 1.5 years old ballpark.
I've had it for about 9-10 months and have done the following:
Newer 39 reds (90%+reds).
Ditched the airshocks for 2.0 radflo coilovers w/ custom valving and resis. Brand new PAC springs.
Added brand new wetsounds stealth 6 BT sound bar.
All new seals/ gaskets / ARP head studs.
Replaced a few brake lines , leaky steering hoses.
New starter (have old one for spare, still works)
New Red top Optima
New GM 1 wire alt
New PS belt with spare
New water pump (have old one for spare)
New header studs
I replaced a lot ^ when I had the motor apart just so I knew it was all brand new.
Light weight , very easy to drive , rides great and very comfy. I'm 5'11-6' , wife is 5'7" . Both comfortable in it.
I can price several different ways.
I've got a spare full front set of 30 spline chromo shafts.
Auto swap parts (bell housing , TC & flex plate for either AW4 or a340).
Spare 39 red on 8x6x5 beadlock.
Spare IFS rear shaft (drum brake crap removed).
Asking 22k and can go from there depending what you want with parts added or subtracted.
(will pull the wetsounds bar for a reduced price)
Good starter rig (a lot nicer than my first rig) , works amazing in the rocks.
Thanks
Here are a few of the newest videos I have of it. Taken this past weekend 4-11-2020.
Price drop to $20k without the spare parts. I'll probably pull the wetsounds bar at that price.
I'll have it at AOP this weekend (4-18) if anyone wants to check it out.
Thanks
