Best d44 ball joints
whiskeymakin
Lets hear the opinions?
I havnt seen anything good on moog...
Spicer maybe?
Anything im missing as far as eliminators yet?
tonybolton
Bypass Crawler
I think the Synergy stuff bout as good as you're gonna get for D30/44 stuff. I used to run the MOOG Gold or whatever top level they had at the time but after about 6-10 months they'd get pretty worn. This was on a full body XJ, exocage and 37's.
FlatlandFSJ
What style 44? I think your running old school waggy stuff? There's plenty of options for the newer style 44, not a whole lot out there for the older stuff. I run the spicer ones in both axles, havent had one give out on me yet. Only had 1 lower that gave me problems, but that was a 30 year old stock balljoint and it took breaking a ujoint and the ears passing each other to start acting funky.
jeeptj99
I gave up and dont worry about them until they get reallly bad or I break a RCV. I mean they have to be almost falling out for me to take the RCV out. I got MOOG because of warranty.
jeeppoor
I run Dynatrac they are rebuildable.
Expensive but I haven't had one fail in over 3 years.
hokie_yj
I saw Nick Barna from Balljoint Eliminators post just the other day that he was working on D44 stuff, he was just waiting on some new tooling to come in.
whiskeymakin
Yep i think ive got a set on order. They should be done this weekend.
whiskeymakin
I didnt think about the differences in the d44s thru the years.
So a 79ish waggy dana 44 is different than a later model 44....balljoint wise?
Im not too fond of them
FlatlandFSJ
Most of the aftermarket stuff is aimed at the jeep 30/44 with the inner C mounted ball joint, the knuckle mounted ball joint is different.
whiskeymakin
Ball joint eliminators guy said the older version will be made first. He is still working on the late model
RocYJ
Member
Isn't the Synergy joints the ones with the raised lines in the joint to get more “bite” once installed in the knuckle?
If so, I would stay away from them, they can ruin the ball joint seat.
RocYJ
Member
To clarify on my earlier post. IMO, it’s best to stay away from any aftermarket balljoint that utilizes a knurled finish. Smooth finish balljoints are usually best, as they preserve the factory bore.
On another note, if you are eating up balljoints consistently on a 44, it’s likely that even the ~$600 Dyantrac balljoints are not going to help. Eventually it’s time to re-evaluate the problem and that usually starts to look like...tons.
Today's birthday
