CheapJ7
Mustache rides?
New issue has developed with the tacoma I can't quite figure out.
Brakes have always been somewhat hard but stopped fine.
New issue is say I am trying to slowly drop off a ledge or brake at low speed creeping down a very steep incline the front brakes grab like crazy. Not a pulsing pedal slow grab, but a very fast and very loud quick grab. Like when you first release the brakes on a downhill that quick grunt they give, except the grunt doesn't stop...
Still work fine on the road except right before you come to a complete stop they do the grab thing. It's way worse at low speeds, but high tension on the brakes.
The Master cylinder has also developed a slight catch about half pedal. I'm assuming this is when both chambers of the m/c engage.
What do you think? Hard pads, warped rotors, or M/C failing.
