corey_moon
Member
- Joined
- Jun 9, 2017
- Messages
- 23
Evil X 2,0 originally built by Blue Torch Fab in 2007.
Price: $35,000
Engine:
6.0 truck block bored .030" over with all new bearings, oil pump, water pump, and pistons
LS3 heads and intake
95mm Holley Throttle body
Engine is a fresh build with just a few rides on it
Transmission:
TH350 with new 2500 stall
T-Case
Atlas 3.8 with 1410 flange style yokes
Front Axle:
Custom Dana 80 with Rockwell knuckles and 4" OD tube
Ouverson 47 spline 2" chromo shafts
4.88 gears on custom Ouverson spool
Rear mounted 2.5" PSC double ended ram
1.25" thick aluminum high steer arms
Wilwood Brakes on Ouverson Super 8 Hubs
3/8" plate diff cover
1410 yoke
Rear Axle:
Dana 80 35 spline
4.88 gear and spool
4 piston wilwood calipers on OEM disc brakes
1410 yoke
Wheels/Tires:
43" SX stickies with about 6 rides on them. Just starting to round off the lugs and get sticky
17" Raceline monster RT232 wheels almost new with typical rock rash
Suspension:
4 link front and rear
16" all black ORIs
Misc.
Brand new radiator, fan and shroud
113" wheelbase
New warn 8274-50 winch with synthetic rope
Axles are completely new with about six rides on them. There is 18K in the axles alone.
I purchased this rig a month ago with the intention of wheeling it while I completed my build. I took it to Burris Valley Ranch once and applied a quick paint job on the existing skins. I will continue to use this as I finish my build, but wanted to post it up to see what options are out there. This buggy is extremely stable and sounds amazing!
Will consider trades, but must be a well built buggy on stickes. No junk please. Since my build is not complete I will entertain trades, but firm on price/value
832 972-6666
Price: $35,000
Engine:
Transmission:
T-Case
Front Axle:
1410 yoke
Rear Axle:
Dana 80 35 spline
4.88 gear and spool
1410 yoke
Wheels/Tires:
Suspension:
16" all black ORIs
Misc.
113" wheelbase
832 972-6666
