8 87yjtoy Well-Known Member Joined May 23, 2007 Messages 237 Location Brandon MS Jan 24, 2009 #1 I am replaceing the bent shaft on my coilover. & the rodend that mounts to the shaft will not unscrew. Am I missing something like a set screw? have not seen one on the rodend anywhere. Any Ideas?
8 87yjtoy Well-Known Member Joined May 23, 2007 Messages 237 Location Brandon MS Jan 24, 2009 #2 A little heat on the end to loosen up the locktite & it came off.
BamaTJ Well-Known Member Hardline Crawler Joined May 16, 2007 Messages 9,970 Location Gardendale, AL Jan 24, 2009 #3 You have to put some muscle on it old man! Mine were a ***** to get off, but they will come
8 87yjtoy Well-Known Member Joined May 23, 2007 Messages 237 Location Brandon MS Jan 24, 2009 #4 Heat was the trick. locktite was good
M muddyblzr Well-Known Member Joined Dec 10, 2008 Messages 67 Location texas Jan 25, 2009 #5 how are you keeping the shaft from spinning? put it in a vice with a thick rag over it?
8 87yjtoy Well-Known Member Joined May 23, 2007 Messages 237 Location Brandon MS Jan 26, 2009 #6 AL vice jaw covers
