D44 Wobble
GRNTACO
This Space Blank
With a psycho
I built a D44 recently and put all new ball joints in it. I put everything together according to the Dana/Spicer service manual. Which said to torque the bottom bolt to 80ft/lbs, then torque the insert to 50 ft/lbs and lastly the top nut to 100 ft/lbs. Everything was fine then after the first wheelin trip I had a 35mph wobble. Took it apart and the drivers side ball joint had some slop (the wheel bearing had a little play in it also) so I tightend everthing down again according to the manual. Wheeled it and the same thing...................:mad:
Am I missing something?
Is the ball joint toast now?
i NEVER USE torqu specs on them ball joints--all by feel. its possable the insert is binding up and you are getting to the torque spec before the ball joint actually gets the correct pre-load...
Any suggestions? And what should I "feel" when I get there?:rb: :haha:
GRNTACO said:
On the knuckle?
Hmmmmm....that makes sense.
Thanks:cool:
No--the inner tube :haha: :haha: :haha: :haha: :haha: :haha: :haha: :haha: :haha: :haha:
Love ya ben :;
So I did it like you said. When I did the passenger side I tighted the insert until there was some resistance but when I tightend the top nut the resistance was gone. When I did the drivers side I did it exactly the same way but there was still some resistance after tightening.......not much. I took it out last night and banged around and no wobble.
Thanks for the help!:cheer:
