Delete
Hotrodpayton
Jesus Saves
$36,000
Clanton AL 35045
205-288-6983 is best
Chassis built by professional welder, powder coated
Blue Print engines LS 408 Strocker, 317 heads, Fitech injection, cam specs in the pics. Have paper work on engine, runs awesome and cool
Goat built accessory drives, no belt issues
Digital gauges and fitech dash monitor with ability to make tuning adjustments
In tank fuel pump, with micro filter and regulator
Custom headers with mufflers
TH400 RMVB, Ultra Bell, side winder shifter, 2 rides on it
4.3 Atlas with front and rear support, cable shifters, 1410 driveshafts
D60 front, spool 5.38's, yukon shafts, Reid knuckles
14 bolt with spool Both have Arctec Trusses
1 1/4" heims, steel links, 2.5 Fox 16" remote res shocks, bumps up front. It rides and climbs amazing, set up perfect for trail riding
Trail gear dual ram full system with filter (awesome)
Willwood single pedal dual master cylinder, stops good
Griffin Radiator, dual fans, trans cooler with fan. Both are controlled by the ecm
AN fuel and coolant lines
New 9,500 winch
BT stereo
Corbue seat and 3" harnesses
Brand New 43" stickies and Vision Beadlocks
Optima Battery with good wiring, easy fuse and relay access
4 led cube lights
I'm the second owner and the buggy is the nicest most dependable one I've ever had. 1 small engine oil drip, and the temp sensor o ring has a drip on the trans pan. That's literally the only 2 things that you could call wrong. It's turn key ready to go right this minute. Pictures are current
I forgot, $36,000
If it don't sale, it's not a big deal. I have had some really life altering changes lately that I'm dealing with. Luckily they aren't financially hurting me yet. But things have really took a turn for me. I planned on actually keeping this buggy, it's definitely a nice buggy.
I would look at a Jk, something the family can ride to the grocery store in on trade
