Sold/Expired Deleted
Jbozwv
Member
Belington wv
It's a 1999 Jeep Wrangler tj 4.0 5 speed
it has a new 02 censor on exhaust new 117 amp alternator and new serpentine belt 2 inc spacer lift new 33 12.5 15 Micky Thompson Degan 38s has Dana 30-35 combo stock gears will run more than highway speed in 5th and 4th to pull hills I do have lockers for it not installed tho (spartan and power trax)factory roll bar older soft top half doors with glass slider uppers newer fold down chevy front seats stock back seat has a light bar up front and a smaller one on the rear bumper aftermarket bumpers front and rear not sure what brand 12000 pound winch also not sure of the bran no stickers on it other than 12000 lbs has aftermarket fender flares with led turn signals has kc head lights with halo turn signals you will never need high beams with these dose have a tow hitch in rear bumper has a hook on a small section of China up front (not sure how much I trust the hook was on it when I got it) also has an illuminated clinometer on the dash the body is pretty much spotless all gauges work heater works great also has fire extinguisher by drivers seat
The bad
First and most important the frame is ruff I will not sugar coat it. Has holes on bottom that will need plated I do have metal for that tho. But don't be expecting a clean frame from how spotless the body is the previous owner must have never sprayed the frame out.
It dose have a rebuilt title not sure why or what happened
The ignition coil I believe it is called is starting to act up. Sometimes the blinker and radio won't turn on just jiggle the key or turn it off then back on and it's fine
Spare tire dose not match was on it when I got it
Not sure of value looking to trade listed under bad since I know you guys are sticklers for a price. Feel free to give some insight on that if you wish I would guess the $6000-7000 ish range I may be way off tho
TRADES
Must be 4x4 winters are shitty here
Would love a cj7 but all wranglers would be entertained
As far as truck older, big blocks, full size are all pluses
No ford 6.0 diesels already went down that road once
I am not a brand snob
Feel free to ask any questions or shoot me offers most I can say is no
Located in Waynesburg PA
Re: 1999 Jeep tj wrangler 4.0 5 speed
Had a deal worked out guy back ed so back on the market
