Cole Well-Known Member Joined Apr 23, 2012 Messages 1,494 May 13, 2013 #1 Anyone know where to buy a driveshaft and the carrier bearing for a 2012 XP900. I warped the crap out of mine on the motocross track.
COPPERHEAD42 Well-Known Member Joined Dec 10, 2009 Messages 1,168 May 13, 2013 #2 check out polarispartshouse.com, or just cut your tube out and make a new shaft, that's what I did when I stretched my xp. also could upgrade to a better carrier bearing while you're at it
Speeding Forum member #1 Hardline Crawler Joined May 16, 2007 Messages 4,575 Location murfreesboro, tn May 14, 2013 #3 Www.partzilla.com too maybe
Budget YJ Well-Known Member Joined Mar 9, 2008 Messages 943 Location Silver Creek Ga May 14, 2013 #4 Carrier is replaced with Toyota one from parts store. Then just retube shaft or partshark.com Here is link for carrier. http://www.rzrforums.net/rzr-900-engine/78356-2012-xp-900-drive-shaft-center-support-carrier-bearing-replacement.html Some are also using the 119 pillow block that has a grease fitting that do a lot of mudding but say it has a little vibration to it.
