Jacobmc
I'm wanting to get the fitech efi 400 for my motor and planned on using the RCI 2161a jeep fuel cell and was wondering what pump I could use for this tank..the guy at fitech said I would need a in tank pump
Jacobmc said:I'm wanting to get the fitech efi 400 for my motor and planned on using the RCI 2161a jeep fuel cell and was wondering what pump I could use for this tank..the guy at fitech said I would need a in tank pump
Goatbuilt has his own tank. Rotomolded plastic, optional aluminum shell, straps, and mount kits. His own fill plates that use a huge o-ring to seal plate to tank, factory gm pumps to plate. Really about the best thing out there. Lots of option for the fill plate; fast fill, reg fill, tractor type gauge cap or not, his own roll over valve, or use the built in valve in the gm pump.RustyC said:Not sure it is possible but, I wonder if yo cut cut the top of the tank with a hole saw and add an in tank pump setup from a GM truck? I think Goatbuilt used an option like that or very close to it.
