Sold/Expired GM CUCV 60 and 14b ff
bannerp
Got a CUCV 60 front complete from brake cailpers to wheels, steering rods u bolt plates everything you need to bolt this bad boy in a K5 or K10 needs a master install kit and ring and pinion put in it. have a used set of 4.56 gears that go with it $700 obo.
14 bolt ff 3.48 gears have a set of 4.56 gears and carrier for it $400 call or text 828 three eight seven 6981 Parts are located in Newland NC 28657
Can text more pics
so no gears in front axle ? passenger side threads good for the top plate ? def interested in the front
The pinion bearing went out on the PO . I have a set of factory GM 4.56 gears from another CUCV for this axle just need to be installed and yes the passenger side threads are fine drivers side are a little rough.
i mean where the top plate bolts to the housing. sometimes those are boggered up
Yea those are in great shape. I have everything to bolt these in a 1/2 ton or K5
I am not holding these axles for anyone, if you want them come and get em. If you want me to hold them i can send you a paypal invoice for the FULL AMOUNT. I have had tons of interest in the 60
