GM TBI question.
JOOP
I WON a COOKIE
Kitsap
Will my GM TBI set-up on my inline 6 work on a V8? The TBI system has been flawless for 10 years. Not one failure except for the time Joe kicked the ground wire loose when wheeling the BYS and SOL trails many moons ago. Other than that its been perfect. So I'm wondering if my system will work on a V8 if I make the swap??
Short answer is yes it will work. It will likely require reprogramming and you should swap out the "limp home" chip for a 8cyl one. Maybe swap injectors depending on some details. No mass air anything to worry about.
