I believe its more evenly clamping force. Kinda like a standard beadlock with 12 bolts vs lets say 24.
Are you talking about the military wheels?
One is for Bias ply the other is for Radials.
I do not know what happens when you mix them, but according to Army HMMWV technical manual this is the case. We were never allowed to mix.
That's what I would think but does it really matter. How many failures are happening with the 8 bolt wheels?
I think the down side is the 16.5 wheels if I remeber correctly. Or are they a differnt size then that?
Aren't the 12 bolt versions heavier? If so, then that extra steel has to be somewhere.
I know that the 8 bolt version also has a lower maximum inflation pressure (30 psi of the top of my head). I would suspect that this has something to do with the force exerted on the studs. Since we always want to air them down, that's not a big issue for us.
the 24 bolt version for radials, but have not seen one without damage.
is it a must to get them recenterd if you ran the on a 60 or do they sick in to far or what?
It's not necessary. It's a matter of choice for what back spacing you want. For me. I need them with about 3.5-4" back spacing. Otherwise I rub on the frame.
thanks how much does it ussaully run to get them recentered?
