Highlighted posts from Tuesday, Mar. 09, 2021
HCBot
Member
Staff member
Click here to view on the web
Highlighted posts
March 06, 2021 * 11 posts * 360 views
poolman said: So I'm considering 14 bolt steering axles. I met a guy at Harlan 6,7 years ago but his number must be an old phone. His name was Alex and he had a much cheaper wayy than a kit. ... Read more >>
March 03, 2021 * 18 posts * 753 views
81yota said: Just kind of curious to see if anyone is interested. 96 Turbo'd Cherokee clean title. 10k Raleigh Illinois Hp Dana 44 front, grizzley locker, chromoly shafts, 5.13 gears, hydro ... Read more >>
March 07, 2021 * 5 posts * 356 views
Kkark24 said: Jimmys 4x4 one off build $95,000 2018 JLU Rubicon 6500 miles Stock motor w tazer Spidertrax Ultra 4 Axle's -4" heat treated chromoly housings - 40 spline 300m shafts - Yukon u ... Read more >>
March 07, 2021 * 6 posts * 177 views
nycreecy said: Meeting a buddy from OH at Harlan. Camping on the Putney side. Anyone going to be there? Maybe join forces or show us around a little. LJ and 4dr, locked/tons/40's TIA, Chan Read more >>
March 05, 2021 * 5 posts * 250 views
30th6 said: Does this look ok? How tight is to tighton backlash? I always run them tight for off-road only. I have about .03 now but everything seems to move smooth. Read more >>
March 03, 2021 * 10 posts * 573 views
baldduck74 said: We had those at the shop I used to work at, they didn't impress me much on anything thicker than 3/16". And you have to grind the step completely gone to sharpen them. Read more >>
March 05, 2021 * 2 posts * 270 views
grcthird said: 4.0, lunchboxes front and rear, 31" Iroks, Rustys 3" spring kit, rebuilt trans and case have less than 500 miles on them. Build thread is here. [link] I don't use it and after ... Read more >>
March 08, 2021 * 2 posts * 95 views
ridered3 said: Looking to upgrade my bumper pull trailer from a 16' with 3500 pound axles to a larger bumper pull trailer. I have looked around at new ones semi local, but wanted to check here ... Read more >>
March 04, 2021 * 2 posts * 281 views
jtc21 said: I've been talking to Marvin . The guy who owns mayham off road I'm sure many of you have been there. As it was some of the best rock crawling in the south East. Middle tn for sure. ... Read more >>
March 08, 2021 * 1 post * 114 views
IRONMIKE said: Putting out feelers for my rolling chassis. It is a 2013 BFR Coupe. This is the first one Tim built. Can be configured as a 4 seater, or a 2 seater. Tim set the suspension, engine, ... Read more >>
Continue reading...
Primary
HardlineCrawlers Assistant
Here are some related products that HardlineCrawlers members are talking about. Clicking on a product will take you to HardlineCrawlers’s partner, Primary, where you can find links to HardlineCrawlers discussions about these products.
