Highlighted posts from Tuesday, Mar. 23, 2021
HCBot
Member
Staff member
Click here to view on the web
Highlighted posts
March 19, 2021 * 4 posts * 270 views
squeak12 said: OEM cast parts cut off to tubes. Caliper cores, brackets, unit bearings, locking hubs & axles included. No rotors. 3.73 gearset. $700. Located near Stony Lonesome in Bremen, AL. ... Read more >>
March 19, 2021 * 3 posts * 575 views
bddisi said: 1997 Jeep TJ Buggy $35,000.00 Location: Cleveland TN I have title in hand. All Tube chassis and roll cage 188 and 120 wall x 1.75 DOM Corp 14bolts front and rear 5.38 ratio on ... Read more >>
March 16, 2021 * 6 posts * 380 views
ToledoDan said: so it seems like stripped drain plugs for differentials is pretty common in SXS, RZRs etc. I have a stripped plug for the front diff. I am sure the guy i paid to do a complete ... Read more >>
March 22, 2021 * 4 posts * 101 views
The Luke said: Factory 14 bolt 4.10 gears. Couple marks from welding splatter. No issues. Pulled to go deeper. $50 Factory super duty 60 reverse rotation 4.10 gears. Couple marks from welding ... Read more >>
March 16, 2021 * 7 posts * 436 views
FlatlandFSJ said: Shamrock Run is only a couple days away..who all is going to morris this weekend? Read more >>
March 16, 2021 * 6 posts * 212 views
jeff150 said: I have (4) 40" sticky treps that are 90%. (As in 90% gone). They hook like a drag slick on rocks. They also hook like a drag slick in mud though. Seriously though, they all hold ... Read more >>
March 16, 2021 * 4 posts * 234 views
sandw said: Need a passenger side axle, 37 5/8" length I Believe. Read more >>
March 20, 2021 * 6 posts * 490 views
tennessee_4x4_man said: yes nick i never got around to comeing over there is a feller in mosurie hes comeing to get these axels sorry guys for the spelling did not mean to mix any one up there sold Read more >>
March 22, 2021 * 1 post * 90 views
ToyotaJGB said: Selling (4) 17"x9.5 Allied steel beadlocks. 5x5.5 bolt pattern. 3.5 backspace. Comes with all new hardware. Rings have been cleaned and painted. Asking 650.00 for the set. Located ... Read more >>
March 20, 2021 * 1 post * 92 views
Tdwest95XJ said: Interested in a set of jk rubicon axles for a swap Read more >>
Continue reading...
Primary
HardlineCrawlers Assistant
Here are some related products that HardlineCrawlers members are talking about. Clicking on a product will take you to HardlineCrawlers’s partner, Primary, where you can find links to HardlineCrawlers discussions about these products.
