Im trying to get my hydro assist to bleed all the air out, I've read alot about bleeding the system. cracking the lines, gravity bleeding side to side alot an can't seem to get it to bleed. Its a toyota on tons single ended ram stock toyota pump drilled out for the mod,the box is tapped in the right spots an the ram turns the way it should,with the ram connected to the line. an not attached to the steering the ram doesn't move until your at full lock, the pump is pumping when I crack the pressure side line but . It might not be pumping enough, I've also read people use the stock pump and it works ok but an upgrade would be better. Its a 2x8 ram an any help would be appreciated
