Mooretoyx4
- Joined
- Jan 3, 2012
- Messages
- 308
So I just hooked up my hydro steering and was trying to bleed the system with the engine and belt off. Everything has been triple checked to make sure it's hooked up correctly. The ram is a psc 2.5x6 and the pump is a TG, the orbital is a charlynn. I filled the resevoir and started cycling the steering back and forth. Most of the air is bled out and I noticed it would start spinning the pump pulley while turning the steering wheel. When you hold the pully from spinning you cannot turn the steering wheel. Keep in mind there is no belt on the pump. I went as far as to try and start the truck with the belt on and when you touch the steering wheel it shakes violently back and fourth like it's going to fly off. We have not been able to cycle the ram at all. Any thoughts? Bad pump?
