Painting Tube
xjmarc
Wannabe Bouncer
Sodomy Daisy
What should I clean my tube with before I rattle can it? I cleaned it with brake cleaner before I bent it but wasn't sure if I needed to do any kind of prep before I throw on a coat or 6 of paint. Thanks
I think brake parts cleaner would work, but when it comes to cleaning a bulk amount of tube, I have preferred dumping acetone on shop paper towels and going to town. Throwing away many paper towels in the process.
Only problem with shop towels is the lent left behind.
I used cloth rags with acetone on mine and I have cases of shop towels I got for free.
hokie_yj said:
Acetone on a shop towel, grip the tube gently and use long slow strokes...
You have a girlfriend now....... easy buddy
I have used acetone many times and it works very well.
ForMud said:
You can use Xylene too.....Stinks to high hell but gives you a good buzz.
That's what I used when we did my cage. started using paper towels but the lent and scraps left behind caused problems so we switched to towels.
Don't forget to gently twist a little as you get towards the end.
