Rockwells607
so I put a hp 60 and sterling 10.25 in a rear engine buggy for a guy, get it almost done and realize it goes forward in reverse and reverse in forward, so here's where im at...take axles back out, flip them over cut everything off and reweld on, cut c's off the front and re weld em on...the front axle can be passenger or driver drop cuz the driveshaft is centered in the chassis on the tcase end....is there anything else im overlooking with the oiling system on the low pinion sterling? That will now be in the high pinion configuration and im not sure if the pinion will get lubed? Any thoughts or info?
