Sold/Expired Rock Bouncer/Trail Bouncer
jeeepinohio
Member
Finished this buggy up in 2017 and have only had it out about 5-6 times since. Only reason im selling is because I dont have time to use it. Extremely Clean Buggy!!! No corners cut.
Metal Worx Chassis, all the main tubes are .188, LOTS OF ROOM INSIDE COMFORTABLE TO RIDE ALL DAY
Newer Square Port LS 6.0 only had 20,000 miles, mast motorsports cam, hardened push rods, dual valve springs, Holly intake, Fast throttle body, Holly injectors, Controlled by Holly EFI.
Turbo 400 trans built by FTI all billet internals. Supposed to be bullet proof.
3600 stall FTI Converter
Atlas 2 Race Case 3 to 1
All 1410 Drive Line
14 bolt front axle from wide open designs, 300M RCV Shafts, 4.56 gears with spool.
14 bolt rear axle with yukon cromo shafts, spool and 4.56 gears.
Wilwood Callipers front and rear
The whole cooling sytem on this buggy is sufficient to beat on it all day and never get warm.
All AN lines and fittings no hose clamps on this one!
Fox 2.5 16 inch travel in the front
Fox 2.0 18 inch travel Rear
Fox bumps front and rear
Full PSC Steering with aluminum tie rods and 7/8 rod ends.
Lower links are wide open designs aluminum with 1 1/4 heims
Upper links are 2 inch 1/4 wall dom with 1 1/14 heims
Corbeu seats
15 Gallon fuel cell with hydra mat and 2 inline pumps. never run out of fuel.
Acumalator turns on and off with ignition
1/2 inch aluminum skid plate
Anti Rock Sway Bar
43 sx Stickys on custom Trail Worth fab double beadlocks
Spare 43 on sticky along with other spare parts
A lot more im forgeting
Asking $34,000. I have over twice that invested in parts and that doesnt count labor to build it. This is a super clean professional build. The pictures were just taken thats exactly how it looks right now. Fully prepped and serviced for next ride. Located in Doylestown, Ohio. Please call or txt me with questions as I don't check this everyday. 330-760-9232. Not very interested in trades but shoot them to me if you have them all I can say is no.
