76nick
- Joined
- May 13, 2010
- Messages
- 269
Bought these from high lifter totaled my rzr next day so I never put them on or took out of the box.
9th xp high lifter high clearance a arm & radius arm
Made from 1 ¼" x 3/16" DOM steel tubing, the Max Clearance Series Radius Bar is a beefy addition compared to the OEM bars (3/4") and other competitors (1"). The simple bolt-on kit also features a 5/8" heim joint with a load rated at 17,955 pounds and polyurethane bushings for rugged durability in the deepest ruts and along the rockiest terrain
The Max Clearance Front Lower Control Arms feature a dual bend design giving you the MOST clearance you can get from the frame to the hub without adding a lift. Our a-arms provide more than 2" of additional clearance where you need it the most. We designed the Control Arm Kit specifically for RZR owners who are concerned about the additional wear and tear on a UTV when adding a standard lift kit. By maintain factory drivelines and positions, there's no added wear and tear on your RZR's components – including the CV axle joints.
The a-arms are crafted from 1 1/16" x .120 wall steel DOM tubing – a serious upgrade from factory materials. Each a-arm features additional gussets adding even more strength where you need it most. Additionally, the a-arms can reuse your factory ball joints and bushings.
paid over 600 with shipping
I'll take $500 for pick up if shipped it will be on your cost
Located in Alexander city Al 35010
Call or text 256-794-3823
