Scott's Custom Off Road Hydro Pump
Monkey Crawler
New Member
I've kicked my PSC stuff to the curb and am going to try a new pump from Scott's. Scott ships his pumps with a relief valve that is -8an on the in, out, and bypass -- my questoin is, can I reduce the bypass to -6? My reservior has a 3rd bung that is -6. If not, I'll just tee back into the other return line. Thanks in advance.
Tee it in the return line no matter what, before the cooler, so you can cool the return flow too.
I know he recommends -8 from the pump to the relief, to the orbital and back to the reservoir. I redid my system and changed out my lines to -8 at his recommendation. Only a few hours on it since swapping, but seems way stronger. I also have one pump running front and rear steer now.
