Shave your bushing?
skipnrocks
Billings Montana
I'm upgraded my king bushing from nylon to brass. Without adjusting down the tensioner at all steering is pretty tight. The manufacturer said to shave it foen a litte. Anyone have to do this ?
It was tight, I replaced the shims in my high street arm at the same time so I'm not sure if it's the shims or the bushing that made it that way. I got hydraulic steering so I just put a lot of grease in there as said screw it.
Well I opted to shave a little off. It was so tight on one side I needed a lever to turn it. Being brass it was easy. And then allowed me to use the adjuster screw to set the tension
