Snapping u-joint straps
417chevy
Sw missouri
First off it's a 94 yj 2" lift and soa with d44 front and d60 rear. my problem is with the rear, due to the short wheel base, I have one hell of a pinion angle. I believe that may have something to do with me snapping u-joint straps. Does any one have a similar set up or has had this problem? Any info would really help. I snapped two sets of straps yesterday.
Axle wrap and straps. Been there and done that.
Sent from my iPad using Tapatalk
If you do a traction bar on the 60. Make sure you truss the housing itself. Traction bars are notorious for spinning axle tubes.
kushKrawlin said:
Man that **** was terrible. I highly suggest a good weld around the tube Atleast. Man that pinion shoots straight the FAWK up and snap!
We should write a book on what not to do. I've got a solid month of **** not to do.
Just waiting on rebuild kits to come in the mail. Will be trying out Saturday
