Started life as a 93 pickup
Motor
22re, has a TRD cam, an LC engineering head, Lc engineering mls head gasket, ARP head studs, head was just resurfaced. Also has custom intake and long tube header, I cant remember which brand.
Tranny-
Stock with Centerforce clutch
Tcase-
Stock with 4.7 gears
Front Axle-
Dana 60, narrowed to 64" wms. converted to six lug with solid hubs and solid 35 spline drive slugs. G2 chromo 35 spline inner and outers. BTF DIY diff cover
Rear axle
Toyota 8" completely rebuilt with a new spool gears and install kit. Chromo shafts. BTF axle truss
Suspension
Front 3 link with panhard bar, 1.25 heims lower with bushings on axle end 2"od .25 wall 3/4 upper 1.5" .25 wall same as panhard with 14" fox air shocks with heavier weight oil
Rear 1" heims on all ends and bushings on the axle side, 1.5 x .25wall with 14" Fox Air Shocks. Also has a Currie Anti Rock mounted on rear axle.
Driveshafts are both .25 wall.
Steering is full hydro with a danfoss orbital, trail gear ps pump and a krc resevoir.
39" BFG krawlers on DIYBeadlocks
Has a GM 1 ton master cylinder and Gm 1 wire alternator.
Buggy has a smitty built winch with some synthetic cable but mostly shot, still have the steel cable. Has a blue top optima, flexalite fan with a new v6 toyota radiator. Buggy also has some 6" lights on the front and 4 point harnesses, Im not sure the brand.
Asking 6500 or possibly trade.
Motor
Tranny-
Tcase-
Front Axle-
Rear axle
Suspension
