Square driveshaft question
Jacobmc
Wetumpka,Al
Is their a smaller tube size besides 2in receiver tube that people use?. I'm getting tired of this rattling mine makes due to a loose fit..I've seen a few people running a smaller size tube but I can't find any info..its going a Toyota
Sent from my XT1254 using Tapatalk
Before you go through the hassle of making new shafts, have you checked to see how much grease there is in the ones you have now? I have run a few sets of square shafts and as long as I kept them loaded up with grease, they didn't rattle much at all. Even driving on the road for short periods of time.
Yea I might try more grease and maybe weld the corners up on the inside peice to get it to fit tighter...I was just wondering if their was some better fitting tube to use
I use inch and a half inside 2 inch on a yota. I first did it with 2 inch inside 2 and a half and that was way too heavy and hit my crossmember. I tapped holes for grease fitting and just keep it full of grease.
