Suspension HELP!!!
mcmen0317
88 4Runner SAS
Byron, Ga
I have an 88 4Runner with a SAS, spring over, high steer. It's tall. I am runnin 38's with bout 6inchs from top of tire to fender. Can I lower it down some without having to change drive shaft length and a bunch of other stuff? Pretty much can I drop it down to run 35's and when a trail ride comes up lift it back up easy to run trails?
Re: Re: Suspension HELP!!!
Yes.
88 on 38.5sx. Rear lowered, front with allpro lift. Lowered front and can run 39 kraelers
If I understand what you are asking. You want an adjustable suspension to raise the truck for bigger tires, then lower back down for daily driving?
I think airbags would be the only logical way to do that. IMHO not worth it.
Combo of stock springs in front, stock rears with 1 long lift leaf and one short lift leaf. Also running 5" btf shackles
No need for adjustable suspension, bump stop to the biggest tire you'll be running and swap tires out as needed.
Re: Re: Re: Re: Suspension HELP!!!
X2
Move your front axle really far forward (redrill spring perches and plates) or tub your cab out
