Chris S
Call,text or pm me if your interested! Chris,931-273-3202 I'm in Hillsboro Tn
4- 85 model brake boosters and master cylinders. Should work on all but not sure. $25 a piece
1-r150 transmission and t-case. 3.0 v6 version $250
1- chain driven t-case from a r150 3.4v6 version. $150
1- (new) trail gear drop pitman arm for high steer. $80
1-22re power steering stock set up. Pump,bracket,hoses and reservoir $80
1- used eaton limited slip for 8" third (tacoma) $200
1 tacoma brake booster and master cylinder off of 01'. $50
1 set of inner fenders off 85 4runner. $40
1-(new) set (3)of auto gauges 2 5/8" black face. $60
1- RCI plastic 16 gallon fuel cell with fuel sender(23"x17"x11") comes with walbro gls394 high pressure in line pump,jegs in line fuel filter,regulator that was leaking(may can be fixed) a/n fittings,stainless braided fuel lines and brackets to hold down tank,filter,and pump! Tank needs a new $26 fill cap. $200
2or 3 sets steering arms for 79-85 toyota straight axle. Make offer
Tailgate for 1st gen 4runner. Good glass and window motor $125
