Just kind of curious to see if anyone is interested. 96 Turbo’d Cherokee clean title. 10k Raleigh Illinois
Hp Dana 44 front, grizzley locker, chromoly shafts, 5.13 gears, hydro assist
Ford 9” rear with spool and 5.13 gears
38” swampers with around 80 percent tread on diy beadlocks
Rustys 8.5 long arm with transfer case skid and sye
Frame stiffners, tree kickers, front and rear bumpers, cage on the inside (it’s tight), led headlights, head was redone last spring with new lifters, water pump, radiator, condenser, Durango alternator. At that time I rebuilt the front end as well.
Heat works, ac works, drives decent down the road but isn’t a Cadillac. I drive it around here and when I need it otherwise i only wheel it I’ve had it for about 2 years.
This winter it got a turbo, 36lb injectors, gm 2 bar map and I tuned it on 10lb. I converted the mech fan to a Ford Taurus single fan all plumbed into the factory wiring and fan speeds adjusted with hp tuners. Override switch in the cab.
Winch doesn’t go with it. I do have another set of white doors. I ended up hitting both driver front and rear doors on our New Year’s Day wheeling adventure.
