WideOpenDesign
Off-Road Parts Superstore
Wide Open Design "Jeevolution" roller - Evolution with Jeep grille
This custom project is based of our production Evolution chassis and modified to use the narrowed Jeep YJ hood and grille. We built custom aluminum cowl and fenders to keep the lines clean.
Chassis: Wide Open Design Evolution
Engine: GM 5.3 with car intake, WideOpenDesign Alternator and Power Steering Relocation Kit. -16 AN Thermostat housing fitting
Cooling Systems: Griffin 31x16 Radiator with dual Spal Fans
Front Axle: Dana 60 with Chevy Dana 60 Wide Open Design Truss
Rear Axle: 14 bolt with Wide Open Design Truss and pinion tie in
Transfer Case: NP205 with clockable adapter with Single-Ended Carrier Bearing
Transmission: TH350, with Winters Shifter
Suspension: Four-link front/rear, 1.25" QA1 Rod Ends (heims), 2.25" 7075 Aluminum lowers, 2" 7075 Aluminum uppers, Air Bumpstops and Bump Can Mounts, 2.0 Fox Coil Over Shocks
Steering: PSC Double-end ram on Wide Open Design truss mount.
Wheels/Tires: 43" TSL SX Stickies, 17" Raceline beadlocks
Misc: PRP Seats, Warn 9.0 RC comp winch
http://www.wideopendesign.com/Project/28/Jeep-Evolution.aspx
