wizzo's buggy
wizzo
glasgow, ky
After beat'n up my Toyota pretty good, i decided it was time for a tube chassis. i need something that will hopefully last for a good while and take some abuse. i kept just a few parts from my yota to use in the buggy.
specs are:
6.0L stock internals (for now) w/ efi live tune, kevko pan, hooker headers
th350 rebuilt by WOD (from yota)
dana 300 with jb conversions 32 spline outputs and 1350 yokes
dana 60 front w/ 5.13 gears, welded, artec truss, ctm joints, superior shafts throughout, yukon drive flanges, 1350 yoke
14 bolt rear w/ 5.13 gears, welded, artec truss and bridge, gubni disc brake conversion, 1350 yoke
PSC full hydro sytem w/ double ended ram (from yota)
2" 7075 lowers w/ 1.25 QA1 heims from WOD
1 3/4 uppers w/ 7/8 ruff stuff heims
14" bilstein coilovers front
17" bilstein coilovers rear
corbeau seats and harnesses (from yota)
16 gallon fuel cell with walbro internal pick ups from WOD
39" red labels (from yota) on 17" KMC bead locks
Few pics
wizzo
glasgow, ky
this is how it's sit'n at the moment
still got a ways, need to wire, plumb, make aluminum floors, panals and skins and i'm sure few other things but hope to be finishing this up in the next lil bit :driving:
wizzo
glasgow, ky
engine firewall is done, part of the floors are in. working on plumbing when i have time this week. so not a whole lot to see right now but making progress. going to summertown and wooly's this weekend so nothing major will get done until the following weekend.
oneton - you started on that chassis you picked up?
wizzo
glasgow, ky
fuel system is plumbed, radiator lines are run, coils are on. took it up to my buddy josh's shop on sunday and he wired the engine and helped joe and i work on the floor. got the buggy over at my work and i'll be coming in and knock'n out about 3 hrs before work starts until this is done.
wizzo
glasgow, ky
belly skid
engine skid
arp studs finally showed up today, front end will go back together tonight and goin for a test ride tomorrow. hopefully it will get skins and a hood before new years......
wizzo
glasgow, ky
first trip out went great! have some cable linkage problems at the transfer case, it's get'n fixed at the moment. skins and hood next week
no hood or skins
wizzo
glasgow, ky
thanks! got the hose from a local rubber and gasket company. they said it would hold up to the water temps and pressure, it's pretty thick. not sure what it's called or the brand. i can get more info if you like, just let me know.
zjtrey said:
great looking buggy dude!
what kind of hose are u running for the radiator?
Thanks!
zjtrey
North Carolina
if you don't care id like to know more..
I'm running hydraulic return line for mine and it needs to be replaced because i've had to couple it too many times- hopefully i can find something a little cheaper to replace it
ETO
While not very cheap this is what i am running on my buggy.
http://www.summitracing.com/parts/FRA-862016/
Or if you want something that can handle a little higher temp they have this but its a good bit more and has a smaller ID.
http://www.summitracing.com/parts/FRA-841016/
Primary
HardlineCrawlers Assistant
Here are some related products that HardlineCrawlers members are talking about. Clicking on a product will take you to HardlineCrawlers’s partner, Primary, where you can find links to HardlineCrawlers discussions about these products.
