Yota Buggy, Tons, Atlas, Stickies PRICE DROP - 13K
ridgerunner6477
108 inch wheelbase 1.5 inch DOM tubing 39" almost new reds on dyi beadlocks
1998 3.4 L 5VZFE V6 with 75k miles ORS harness 12 volt guy switch panel
Toyota automatic transmission
Atlas 2 transfer case 4.3:1 1350 u bolt yokes
Taurus fan
Beard seats with PRP belts
Rigid 20" E series light bar
Smittybilt 8k front winch with rope
Warn works rear suck down winch
ARB compressor
Chevy D60 4.56 front with ARB 35 SPL locker
YUKON 35 spl outers
BluetorchFab front truss
REID racing outer knuckles
PSC full hydro steering
New 2" double ended ram
Chevy 14 bolt rear with BluetorchFab truss
BTF disc brake conversion
4.56 gears and Detroit locker
1.5" x.250 upper links 3/4 chromo Teflon heims 2" aluminum lowers with 1-1/4" joints
Double triangulation. Tilt column for bigger folks.
18" SwayAway air shocks 1/2" poly skid plate and boat sides. New wilwood masters. Sure I'm forgetting something. Located in NE PA. 18844. 15k. I'll get more pics loaded as soon as I can.
A few pics
What are the dimensions of the rig? Width; overall height; overall length; belly; etc?
Also what size gas tank?
Ok Heres some dimensions. 140" total length - 108" center to center(wheel) 80" to top of cage - 51.5" Cab(insde to inside of cage) - Outside to outside of tires - Front 85" - rear 81" - Belly 21". I believe the tanks a 12 gal.
Did this start life as a taco and gradually become a buggy or did it start as a chassis?
