Sold/Expired 1 ton yj project/ part out
tfreeman
Active Member
1994 jeep J tub and frame. 100% rust free. clean title. factory dash has been replaced with custom aluminum dash. all gauges are new. Hard top is in good shape. All lights are fully functioning. Bucket racing seats with 5 point harness. Paint is in great shape. Shackle reversal up front.
Engine is a 4 bolt main 350. No smoke. All seals and gaskets are new. New alternator, steering pump that has been drilled, and starter. mid rise intake with holly 4 barrel that was just built. New plugs and wires. oil has about 45 Min's of run time on it. Heads have recently been checked and shaved. not 100% sure how much.
Trans is a 400 Th. new pan and gasket. No slipping. Pulls great. T case is a 205 that has been twin sticked.
Front axle is a Chevy kingpin 60. 456 gears and locker. 35 spline outers.Warn lockouts. Axle was just went through. All new seals,bearings, brakes, and oil.High steer arm from eor.
Rear is a 14 bolt ff. disk brakes, 456 gears, lockrite locker. New bearings and seals also.
16 x10 steel wheels with 35x12.50 mud tires (about 50 % tread left)
All that is needed to be a driver is drive shafts and shocks.Still has factory cage.
20 gallon fuel cell mounted in the rear. red top optima that's also new.
The price like it sits is $6000. But I will also part out.
Parts Price List
-Tub and frame (includes grille) $1600
-Engine fully dressed $800
-Trans and converter $550
-T case with sticks $450
-hard top $1000
-1/2 doors $250
-full doors $800
-axles $1500 for the pair or $1300 for front and $ 500 for rear
-wheels and tires $400
-Fuel cell $100
-4" lift springs (brand new) $400
I'm having a hard time with pictures. But I can send them to whoever wants them/ would like to post them for me...
Call or text (931)-994-1860 Located in Centerville TN.
Pics I was sent
More
Last ones.
I'm interested in the 205 & cross member if your other deals fall through. I spoke with you on the phone. My name is Jesse and I am in Spring Hill. Can bring cash whenever. Thanks
