S27 Crawler
New Member
- Joined
- Jan 22, 2019
- Messages
- 4
For sale is a 1968 For Bronco. Located in 46112. Indiana. Willing to help/ arrange shipping to anywhere in the lower 48. $25,000. Contact Jon @ 9two5-five84-6seven0two.
Body/ exterior
-No rust. All sheet metal was replaced from the A pillars back except for the floor pan. New doors, and tailgate.
-Entire outside of body has been line X with the ultra series. Ford raptor gray. (smooth stuff) The top is done inside and out, same with the doors.
-All new window seals and door seals.
-Fabricated bumpers front and rear
-Warn platinum 12.5 synthetic winch , with wireless remote (not pictured)
-LED hid head lights and off road lights
-LED under body lighting
-Battery disconnect
-6" lift with coils in front and leaf springs in rear
-(5) 37" Good year MTR Kevlar tires mounted on 17" diy bead lock wheels
-Spare set of drive lines
Interior
-Full roll cage connected to frame
-Tuffy security center console, tuffy security glove box
-Corbeau black suspension seats with lumbar support
-Dura-liner entire interior floor and sides inside
-15 gallon fuel cell with edelbrock 150 psi electric pump
-High lift jack mounted to cage
-fire extinguishers mounted to cage
-Auto meter gauges
-Simpson racing 5 point harness mounted to roll cage
-Clear lexan panels mounted to floor pan to see the front tires
-Removable door hinges
Engine
-multi point injection 5.0L. roughly 35,000 miles, High flow water pump, Wild horses aluminum radiator, fabricated motor mounts, serpentine belt set up.
-Yellow top optima
-ZF5 Transmission. 5 speed manual
-Atlas 2, 2 speed transfer case
Steering
-PSC hydraulic assists set up with 1.5" ram, external reservoir
-bullet proof cross over steering with 1" heims
Brakes
-Hydro booster run off of power steering pump
-Disc brakes all the way around
Front axle
-HP Dana 44, 4.56 gears, grizzly locker, HD diff cover, chromoly shafts, Yukon lock out hubs
Rear axle
-Currie enterprises 9" housing, with Nodular 3rd member, 4.56 gears with grizzly locker, pinion guard, 31 spline chromoly axles.
-Rear axle is moved back 6" over stock
-Wheel base is about 99"
Body/ exterior
-Battery disconnect
Interior
-Auto meter gauges
Engine
-Yellow top optima
Steering
Brakes
Front axle
Rear axle
