1974 Styler Daimler Puch Pinzgauer 710M troop carrier
$15,000 USD, includes manuals and several spare parts
Located in Madison Alabama
2.5 liter gas, 4 cylinder, air cooled, 90 HP
Transmission: Five forward gears, one backup gear
Transfer case with low gears
Shift on the fly to 4 wheel drive
Shift on the fly for differential lock (100%) front & rear
Suspension: Independent Pendel Axle front & rear coil springs
Dimensions: Length: 4175mm (164.0") » 710M & 710K
4955mm (195") » 712M 6x6
Width: 1760mm (69.25")
Height: 2100mm (82.75")
Wheelbase: 2200mm (86.6") » 710M & 710K
2000mm + 980mm (78.7" + 38.6") » 712M 6x6
Ground Clearance: 335mm (13.25")
Empty Weight: 1950kg (4300lbs.) » 710M & 710K
2400kg (5300lbs.) » 712M 6x6
Payload: 1000kg (2200lbs.) » 710M & 710K
1500kg (3300lbs.) » 712M 6x6
Electric: 24 Volt waterproof system
Trailer Hitch: Pintle hook with 24 Volt connector
Trailer Weight: max. 2250kg (5?000lbs.)
Fuel Tank: 1 tank @75 liter (20 gal.), 1 canister 20 liter (5 gal.)
Accessories: Spare Tire, Tools, Snow Chains, Owners Manual English
Color: Swiss Army green
