Not your toy 85
I bought this cj a few months ago from a board member on nc4x4. I purchased with motor not running and had plans to keep it and wheel it, needless to say plans have changed and i need to unload this jeep soon. i will list the specs, build sheets, dyno sheet for motor along with pics. Jeep runs and drives now and sounds great. Asking $6000 obo
1983 cj 7
Body/frame
yj tub on cj frame. Tub has been taken down and sprayed with speed liner and then sprayed with clear and glitter.frame had the same treatment but painted black. 6 point cage all points tied into frame.
Engine and trans/transfer case:
-LA 360 (410 stroker)
-Timing chain #9-110
-Comp cam #20-223-3
Grind #CRS XE268H-10
-Eagle rods # 356-SIR6123CB
-JE 16.9Dished# 220157
-Mahle clevite rings#315-0036 .045
-Sealed power hydro lifter #2011-16
-Comp valve springs # 986
-Comp retainers #740-16
-Comp super locks #611-16
-Clevite main bearings # Ms1051p
-Clevite rod bearings # cb481hn
-4" scat cast Crank
-Cast iron heads with Chevy valves -believe 2.02
4.040 bore
4" stroke
6.123 rod
366 hp
464 tq
-holley truck avenger 670
-Trans is 727, rmvb, b&m ratchet
-Twin stick dana 300
Axles:
-First gen dodge dana 60 external drive flanges 4.56 welded
-Dana 70 rear 4.56 welded
Tires:
-38×14×16 toyo mt 80%
Suspension :
-Rear is xj leafs Sprung under with daystar boomerangs.
-Front has slider setup with out boarded 44044 springs.
misc.
- -6 nylon braided fuel system
- airtex electric fuel pump
- jazz 20 gal. Tank converted to gravity feed.
Located in winder Ga
678-936-6996
1983 cj 7
Body/frame
-Comp cam #20-223-3
-4" scat cast Crank
4.040 bore
4" stroke
6.123 rod
366 hp
464 tq
Axles:
Tires:
Suspension :
misc.
678-936-6996
